Got a problem with my 07 T3 Verso, i have three lights that come up on the dashboard, the engine light,
TRC light, VSC light, all came on after going over a bump in the road,also a knocking noise coming
from the rear of the vehicle and lack of power but the car is drivable but seems to want to stall.
Any advice or words of comfort will be much appreciated.
Stretcher :crybaby:
Just an update, took it to the local Toyota dealership and the ignition coil needed replacing.
The knocking noise was coming from the exhaust as the revs dropped, it vibrated against
the heat shield, i bent the heat shield away from the exhaust slightly and this helped before
i got it fixed, and now all is fine apart from my bank balance being £230 down.
Stretcher :huh:
