Avensis T3X
Deakin
Hi guys the Deakin here just changed the car recently to a Toyota Avensis T3X 06 facelift model, and need some help has anyone experienced when the car is under pressure eg going up a hill in the wrong gear that the car is pretty noisy, as if it has a hole in the exhaust but it only seems to happen at low speed.Thanks for any Help.
Get same noise on mine 55 plate,had no problems.
Good Morning Mentlegen,
Sounds like you have a very curable problem what which Toyota had a TSB/Official Fix for.
Where the air intake pipe passes through the wing bulkhead on its way to air filter box, it vibrates at a low frequency against said bulkhead, resembling a hole in yer exhaust or a poorly serviced Chinook Helicopter.
Cure consisted of some sound deadening tape judiciously positioned and prey hesto....noise gone. One or two members traced and cured the fault by themselves...nah...it's a design fault...get it fixed.
Go speak Mr. T and see if still doing under warranty. Great car, Deakin....just listen out for the odd noisy injector, which that era was a wee bit prone to. Ah loved mine......
Big Kev :thumbsup:
Thanks for the the reply Kev but this is not the problem i have aready done this at the air intake, this is something else and it only happens when the car is under pressure,when i have 4 passengers in and i put it into 3rd gear to soon then i will get it.Otherwise it is fine plenty of power ect.
I remember having the same problem years ago on an old Ford Escort. It worked out that the engine oil was to low and caused a rattle noise when under load going up hill with a few folks in the car. might be worth a look :thumbsup:
