Spring Opener/closer On Small Storage Box On The Left By Handbrake
The Cav
Hi People
the little storage nik nack with the spring loaded opener closer (flap)
by the Hand brake on the left of the Centre consul
mine wont stay closed ....there are part numbers on the pieces
are they readily available...has anyone ever repaired replaced the said part
i have now removed it for the time being so i can close the flap until i can repair/replace
the part
any help-advice gratefully received
My 2006 T3X had this repaired under warranty in 2008 as it was a Toyota Part Failure. The whole tunnel cowling at that time was about £90.00 + VAT. If you have no warranty or redress on a Toyota main dealer, I would learn to live with fresh air getting at that area....expensive repair.....?
Big Kev :thumbsup:
Mr T in Liverpool has quoted
ARE YOU SITTING DOWN
£140+ - +VAT = A LOT
Evidently you have to buy the centre consul piece complete with the coin box( that's what it is according to MrT)
you cannot buy just the locking Mechanism ....even though it has a part number
I have made a repair to the Mechanism but it is not 100% work every time when closing the flap ...you have
to push it closed a few times until it catches
according to Mr T this is a very common fault
BTW A local breaker wants £25+vat for the part
Mr T in liverpool has quoted
Evidently you have to buy the centre consul piece complete with the coin box( thats what it is according to MrT)
to push it closed a few times untili it catches
Dead right, Cav....it's a very common fault....Toyota's Far King Fault !!!!! I personally do not know how to do this, but feel sure you should be able to trace a Toyota Service Bulletin (TSB) ON THIS VERY SUBJECT.
And I note the bleeder has gone up from about £90-95.00 to £140.00 in a couple of years.....J.H.C.
Big Kev :angry:
Now repaired
Trip taken to a Scrap Yard..... Parts including the coin box and
small piece of centre consul......£25 + VAT...total cost £30.00
Much better than Mr T's....£143 + Vodka And Tonic
