4.3 Engine Tone
webleymk3
They make some funny noises at times Norman. They are quite highly tuned diesels with a particular diesel knock that can sound quite harsh under certain loads. Probably nothing to worry about but take it to your local dealer for a listen if you are concerned. If they are remorely concerned they will rebuild the engine FOC.
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
  • webleymk3
    9
  • El Bee
    9
  • anchorman
    8
  • Big Kev
    6
Thanks Anchorman
Not concerned with my diesel engine. Just that after all my life driving petrol engine cars, the last a very sweet 1.6 vvt vauxhall, the tradional sound of a diesel gets some getting used to. Does intrude into the cabin at times.
Quite like the throaty note during acceleration, which i assume is from the exhaust.
All. Since having the rav my biggest gripe (apart from the awful 1st to 2nd gear change) is the engine tone. It sounds like a proper tractor!
I've become particularly interested in this as I was out in my father-in-laws Avensis which he tells me has the same engine and it was quiet and smooth - like I'd expect from a modern diesel engine.
Another comparison is against my brother's A4 which is a 2.0 diesel and is again quiet and smooth.
What's everyone's experience of their engine sound and how it compares to other diesels?
Thanks.
Web
Hi
I have a T180 and find it's the same
You proably will find the rough change from 1st to 2nd gear is down to the dual mass flywheel/clutch system on these cars
My friend has one and replaced the whole assembly with a standard type flywheel and clutch and solved this problem
Hope this helps
