Water Pipe
keekytiff
I have a 1995 Luicda and the steel water hose from the radiator top hose needs to be changed
I have a new part, but the turbo oil pipes are in the way
If I undo these and catch the oil, where do I re-fill the oil?
Does it self-fill from the engine system, which I can top up normally?
Thank you for anyone's help
as long as the oil level on the dipstick was ok before you started,just run engine for a short while to refill what you lost out of the pipes,which i dont think will be very much.then top up in the normal way.
and a welcome to the forum :thumbsup:
