Avensis Acceleration Problem
a.mac
Hi
I have a Toyota avensis 2.2 d4d, 60000 miles full service history to date.
Yesterday I noticed that when accelerating I have a loud noise (like air escaping) from the engine bay. It does this in every gear and even in neutral when just revving. I have no engine warning lights.
I have contacted Toyota and have booked it in for Monday morning, just wondered whether anyone had a similar problem.
Any help would be much appreciated.
Hi
hi mate
these are injectors play with you and need calibrating
cheers/Igor
Hi
Thanks for your reply. So your saying there is play in the injectors and they need re-calibrating.
How much do you think this will cost/ is it a big job
Hi
I have took my 07 Avensis 2.2 D4D to my local toyota dealership this morning. Have been told that i have a tear in the turbo pipe
and a new one is needed. Been quoated £189.00 inc VAT.
Just thought id keep everyone up-to-date incase someone else has a similar problem.
thanks
Hi
thanks
Why not get a second hand pipe from a breakers yard? Bet it wouldn't cost much more than £40 for one! :yes:
Its very common for the intake pipe to come off the throttle/venturi body underneath the inlet manifold. This is the most likely cause so normally needs refitting only for a minimal charge. The N/S/F intake pipe also sometimes pops off the intercooler. Never seen a pipe tear though.
