Brake Upgrades 80 Series Landcruiser
brockoff77
i own an 80 landcruiser and the area i live has quite a few steep hills as i am a tradie i need to tow a lot of weight and i need to be able to slow down goin down hills with all the weight. before you say use your engine as a brake, the hill i have to decend on regular occasions has alot of flatter sections in it but not long enough to go up a gear so i would like to know if there are any larger disks that i could put on the front to slow me down
Hi and welcome to toc.
i am sure if you post your question on your brakes on the forum covering landcruises you will get some advice.
