Wanted ! Turbo
luke4x4tech
Hi everyone I am in need of a turbo unit for a 2003 rav4 if anyone has one or knows of one going cheep
inbox me with details thanks
you'd better to contact Mr Parts King
cheers
I work for toyota and get parts at cost so don't think he could help can get it rebuilt at essex turbos but still £450 :-(
Parts for the garrett turbo basic rebuild excluding turbine cost me less than 50 quid. If yours is variable vanes sticking its a doddle to strip , clean and replace bearings etc just done mine. Only problem is balancing the unit,special equipment needed but if you live near a turbo rebuilders they will do a balance only at a fraction of the cost of a full reman turbo.Mine worked a treat after . One thing to watch for though is the dreaded snapping bolt, 3 went on me !
Thanks for the reply but mine has snaped the shaft and filled the engine up with oil bending the con rods :censor:
the turbo is mashed inside so it's US :rolleyes:
