Avensis Drl Does Not Work All Time
avast
Hello, i have toyota avensis made in 2007.
The problem is that daytime running lamps only work when headlights are on. This problem occured when backup light fuse went off (we were trying to connect parking system and when testing where is the +, we got a fuse). So i changed the fuse GAUGE 2 FUSE, now backup lights is working ok, but DRL only works when headlights are on. Before an accident, DLR were working fine alone.
Where could be the problem? Maybe i sohould change other fuse, which one?
IS it after market DRL?
As far as I know there are no DRL on 07 model.
If it is after market DRL, and comes with 2 wires (+ve and -ve), simple you need to put the +ve with switch wires.
As soon as car starts they should turn on.
However if your DRLs come with 3 wires, then its different.
But everything was working till the fuse. Maybe i should check some more fuses near the driver seat?
