Mr2 Spyder Stalls
Lil' Red
Last year I finally solved the problem of my 2002 MR2 Spyder stalling out intermittently on the road and highway. As it turns out, there's a computer behind the drivers seat underneath the top stowage compartment that was getting wet. It was caused by the drain plugs clogging in the stowage area and the water was falling down and causing the computer to malfunction. To fix it you'll have to partially raise the top in order to gain access to the plugs and then clear them out.
That's it! Problem solved and life is back to normal.
I hope this helps.
Lil' Red
  • 4 weeks later...
