Charge Or Change Battery
avast
Hello.
I have a question. Is it safe to remove Battery if i want to charge it remotely. Will the computer which controls the car be reset? Or is it completely safe to remove the Battery and then put in in its place after some time?
With modern cars it is sometimes not advisable to disconnect the Battery due to "upsetting" the ECU. You can buy a special device which plugs into your cigarette lighter and this keeps the power supplied to the clock, radio, ECU, central locking etc when you disconnect the main Battery.
http://cgi.ebay.co.uk/Computer-Memory-Saver-Car-Radio-Code-Digital-Clock-NEW-/260694395390?pt=UK_Diagnostic_Tools_Equipment&hash=item3cb298c9fe
its not going to do any harm on your car to remove the Battery for charging.some owners do it on a reguler basis as they find it helps with fuel consumption
you will have reset things like preset rado channels and display settings.
