Avensis Wheel Size
dino_01uk
can any1 please help??? does any1 know what size wheels are on my avensis 2.2 d4d t4 ,as im thinking about putting some bigger alloys on it but dont know stud size or offset or bore to look for ???thanks any1
i think u have 17'' alloys they are not the same stud size as the 2.0d4d t-spirit. Yours i think are the same as the Lexus 220d 250 im not sure of stud size but someone else on here might tell you
which year/model of Avensis?
the studs on a T25 are 5x114 & iirc bore is ~60mm but you can find both bore & offset on the internet if you search (or somebody else may pop up here with confirmed figures). These may have changed for the T27 though.
The 2.2 D4Ds use a different size from all other engined Avensis.
& don't forget to check with your insurer what changing your alloys will do to your premium ....
