Toyota Camry Vvti 2.4.
gregray02
I have a problem with my car, whereby it gives the following fault from the code reader “Catalyst system efficiency below threshold (bank 1)”.
I have been able to obtain the following values from the sensors etc after the codes were removed:
Absolute throttle position 15.1%
Ignition timing 10º advance
Short term fuel trim bank 1 2.34% lean
Long term fuel trim bank 1 10.94% rich
Intake air temperature 35ºc
Bank 1 sensor 2 0.720 V
Before the codes were removed, the values at the point of the DTC occurring were:
Short term fuel trim bank 1 3.91% rich
Long term fuel trim bank 1 8.59% rich
Engine speed 1808.50 Rpm
Vehicle speed 25 Mpg
Intake air temperature 31ºc
I look forward to any feedback. I have posted this onto the site honestjohn, (http://www.honestjohn.co.uk/forum/post/index.htm?t=86617) but nobody could respond.
Greg
