Avensis D4D 2001 Flywheel
brandaopj
Hi:
I need to replace my flywheel and clutch. I would like to know if there any OEM Flywheels that you can recomend because the original is too expensive.
Is there any conversion kit available to change to a solid flywheel? From Toyota or OEM?
Thanks in advance for your help.
Hi:
Try searching on eBay. You can find genuine Toyota clutch kits on there. Look out of LUK kits, as these are the ones made for Mr T... :thumbsup:
i changed my dmf on my 02 d4d to a solid flywheel about £400 for whole job . used a carina flywheel .hope this helps .
I just replaced mine.
LUK kits are avialable on eurocarparts.com
Spoken to several garages independent / main dealer and all advise against going with the solid flywheel.
Today only there is 30% off.
