does anyone here know what degrees the 5efhe timing should be set at? I just recently installed a 5efhe and i'm not sure if the timing is set at the proper degrees before top dead center.
is this kene from TO? i was gonna ask these guys if they knew about it ;). if this isnt kene, then someone answering this question will help me and another tercel owner! thanks guys.
vince
10 degrees BTDC.
