I need to flush out the old coolant in my Toyota Previa (1994 Solair model) and top-up. Would be grateful if someone could tell me the easist way of doing this (which pipe to disconnect etc).
Cheers,
Hiten
Cheers,
Hiten
I haven't done this on any of my Previas - but would guess the radiator hose would be the easiest to access. Drain the system, replave hose and fill up with a flush or just clean water and run the engine for a little....then remove hose again with engine stopped of course and drain out again. Unless you have access to a ramp, then the engine is pretty tight to access. Good luck and let us know how you get on.
