Scv Removal
baz1631
Help! How the :censor: do u get into the scv to remove them? ive@: removed header tank
wireing harness
dip stick
rubber piping
was goin to remove the fan housing, then thought.no! surely there must be an easier way. any help greatfully recieved! Thankx in advance :thumbsup:
wireing harness
dip stick
rubber piping
check with all the pinned section where this topic is.
cheers
Put it on ramps and take the plastic shield off. You can look straight up at them there :thumbsup:
Thankx anchs, :thumbsup: think I'll need to get another 10mm spanner and bend it!
Nope! Tried evrything. cant get spanner onto bolt cause' the scv's too broad,tried allen keys.wont budge,.............everything exept sawing off from the edge of the block!.................I must have the most awkward scv's in a rav :crybaby:
Post a photo Baz. I can't imagine what you are struggling with.
sorry Anch, cant post foto: phone/camera on the blink! gettin worn out like me!)The bolts sem very tight and the allen key just slips when turned.they never seem to make a deep enough space for the allen key. gonna try again tomorrow with LOTS & LOTS of WD40! BTW, are the bolts in my scv 9mm or 10mm?
Tried again! ha ha wasn't wearin the proper specs. ......not a normal bolt at all! just need a magic allen key now to loosen the :censor: things!
have those photo learnt carefully -- both SCVs can be undo by means of one wrench (12 or 13 or 14) as far as I ve caught the scale. You can use socket one as well -- what would be better there. DO not invent a bike -- it has already been invented mate :)
Good luck/Igor
Good luck/Igor
Dear Igormus. a wrench to my knowledge is an adjustable spanner, which will not fit the said bolts what is 12 or 13 or 14?
millimeters?or micro-millimeters? cause niether of these sizes will fit the bolts
Good luck/Igor
no way with adjustable wrench there ---- both flanged type SCvs are subjected to be undo by a normal way using both socket wrench with ratched handle. No offends MATEY !!!! we just wonna help you. You can also use allen type wrench but with ratched handle -- the reult is the same. CHeers/Igor
Good luck/Igor
Priceless :lol:
Baz
Do I understand you right? You are trying to undo the screws that hold the SCVs into the fuel pump?
I can see from the photos in the pinned section that they are cap head allen screws so no spanner is going to get them out. If the hex is cream crackered then you will have to revert to more severe means. That means knocking something in a bit bigger, you might just get a stud extractor in or if you use a small sharp cold chisel to dig a groove in the right hand side as you look then angle it down and tap it anti-clockwise. The look like 6mm metric to me so you should easily be able to find some replacement screws.
If all else fails you will have to remove the pump but it is a big job so avoid it if you can.
Good luck/Igor
Priceless :lol:
Baz
Hi guys again, sorry Igormus didn't quite understand wot u meant by wrench . Got hold of a set of hex keys with ratchet adaptor will attack scv after av had ma tea! will keep u posted . thankx . PS hope it dosen't come to that anchorman!
Good luck/Igor
Priceless :lol:
Baz
Cant quite get the ratchet to fully "pull" the screw .Is there any way of extending the stroke? ie: an extention to put over the ratchet arm? maybe?Anyway am goin inside now....the midges are on the hunt.AAAAARRRRRRRRRRRRRGH :crybaby:
Just find a tube or something :unsure:
YEA, CHEERS ANCH, work 2morrow, then workin over on Tiree (inner hebrides) @ weekend , so wont get bak to it till next week! plenty of time to think about it! Cheers again. will keep u posted! :thumbsup:
YESSSSSSSSSSSSSS! got the BACK one off first with allen key and a tight fitting socket, then the back screw of the front scv, but the last one (always the last one aint it?)I think the hex is :censor: , will try again with a thin long cold chisel providing the !Removed! midges are'nt out playing! (the scourge of scotland !!!)
You need to buy some of the cheapest anti allergy tablets from any of the supermarkets (my mrs found 2 boxes for £1 in Morrisons). Take one a day until the little bggrs have gone. You may still get bitten but you won't react to them.
I start taking them 1 week before hols and never have a problem.
They won't get that screw out though :rolleyes:
u can also use "skin so soft" from a well known beauty co. even the mod use it an' they WONT bite! (ha ha hs probably invented in scotland!)
All done :yahoo: three bolts came out nae bother, but the last one? nightmare had to use anchormans advice (not that I wouldn't!)and use cold chisel..well I used an old wood chisel an' it was hot by tahe time I'd got the bolt to turn!.still, all's well that ends well! (another one for igormus)cheers Gentlemen for all your thoughts and advice. JOB DONE :thumbsup:
hi matey
when installed new/old bolts -- it is necessary to put a bit of antisieze copper compound on the bolt/s threads -- this will allow to unscrew them easily (on the next time). Cheers/Igor
