Anyone Know How To Change The Rear Speed Sensor On My Auris?
biggav85
that didn't quite work like I thought it would? I need to change the rear speed sensor on my auris, I know that its in the back of the rear hub however, where to access it from there i'm unsure. Any help would be greatly apprecited!
Cheers G
Hi is this the ABS sensor you mean
was put on the diagnostic and it came back saying rear nearside speed sensor, although it is the abs light comes on. Apparently it's at the back of the hub and the rear cv joint needs to be undone. Any ideas how to fit?
cheers
em unless you have the worlds only 4x4 or rear wheel drive auris you wont have a cv joint at the rear...and no its not at the back of the hub...it is the hub not too hard to do unplug the wire,remove the caliper and disk then you will see the 14mm bolts that hold the hub in remove these then hammer hard till the hub pops out the axle
i did wonder when the guy in the garage said that but i just agreed to get the hell out of there, Arnold Clark aint my fav people right now and the boy looked clueless! Cheers for help with that much appreciated, all i need to do is buy the part, n it aint cheap, £200 n its dealer only on the rear!!
yip mate the yaris,auris,urban cruiser etc are all the same(not the same part no)but yip they are expensive
