Oil Pump
lee123
hi...
i have a 1991 celcia and it have a 3sge rev 1 engine, the oil seal round the oil pump is leaking so im looking to put a new oil pump on,
on looking for an oil pump i can find lots for 3sgte 5sfe, they look the same, do anyone know what ones will fit
lee
The 94 - 98 Celica can also have a problem with a leaking oil pump seal if the seal isnt changed at higher mileages. Running old oil will make it worse.
This problem is easily fixed by replacing the seal which is a tad expensive ($100 NZ)
Your pump may be fine, but Im sure they wear out sometime too.
