Dpnf Air Pipe To Catalyst
tubaman
D4D - T180 2006 engine.
I'm pretty good at cleaning the EGR Valve - any ideas how to locate the air pipe & adapter to the catalyst can be found ? I understand it can get blocked with carbon quite easy, I would like to locate it to give it a good clean out.
its down the back of the engine mate...its a big job also can be a real pain if you strip the threads then its £1000+ to put right
