Hi guys.
Is anyone able to tell me the external dimensions of toyotas iQ glove bag and the popper size?
Many thanks
Chris
The deco-piece is outside 35 cm x 24 cm x 4 cm (curved).
All iQs have it as standard in Germany, but dont put things in: it is only fixed on four poppers / press studs.
Popper size?
Thanks for the info. By popper size I meant press stud size.
Thanks again La la. Much appreciated.
Chris.
Chris.
Chris,
The popper size is the "normal" size of popper that you get in haberdashery stores. I don't know if there is a European or British standard for such things.
The male part that fits into the other piece has a diameter of 10mm.
The same size of poppers or press studs are also fitted to the tonneau cover and it's fittings inside the rear hatch area on the interior panels, so you could use them as a guide.
John
