Avensis 2Ltr D4D 57 Estate Pollen/ac Filter
Dan1979
Can anyone tell me where this is please? Alittle researce tells me in the drivers foot well but i carnt find it
Hi Dan it's behind the glove compartment on the passenger side.
Pete.
This is how to change it... If I remember correctly
Open the passenger door and the glove box. You'll see on the side of the glovebox a small slide that stops the lid from dropping, there you'll find a small screw. Undo that and the lid can be removed. You can see the filter. Remove that and then I'd get a small vac and carfully give the Denso electric motor a clean if any of the leaves ect have fallen when you removed the old filter. Make sure that you put the new filter in the right way! and then reverse the sequence to put it back together.
Job done and time for a cuppa :thumbsup:
Will only take you 10 mins at most :toast:
