Gen 2 Coolants
Thiva
Hi Everyone
can anyone help me on the following
1. do you have to change the gear box oil and at what milage
2. The Hybrid system coolant - which Milage to change
3. how to check whether the milage is genuine
4. The inverter - servicing and other
Hi Everyone
Hi there...
All the questions above will be answered in your handbook. I would have a look myself but the book is at home and I'm at work!
I suspect that 1 and 4 will not be very often, number 2 is probably every 2 years. As to number 3, depending on how old the vehicle is then the mot certificate may help, or an hpi check....
:thumbsup:
Hi
Easy answers on this one
1. No change schedule, just check levels every four years.
2. System is filled with pink super long life coolant change every 10yrs/100,000 miles ( same as engine )
3. Usual stuff check paperwork, contact dealers
4. No servicing required.
:thumbsup:
No requirement to change from Toyota but it seems prudent to change at 50/60,000miles as people that have done it report the oil to be very discoloured by this time. See Priuschat for more info.
