Automatic Electric Windows, Not Auto?!?!
PeaJay
I have an 04 T3-X. I had a little trip into the hospital, which meant it didn't move for 2 months... Hence dead and would seem unrescueable Battery...
Anyway, I popped along to the local Halfords, one new Battery fitted. However, on the way home, noticed that the electric windows no longer seem to do the auto open/close thing??? They still work, they go up and down, all round, but they dont do the auto thing????? Any ideas, Is there a reset I can do???
I have an 04 T3-X. I had a little trip into the hospital, which meant it didn't move for 2 months... Hence dead and would seem unrescueable battery...
Anyway, I popped along to the local Halfords, one new battery fitted. However, on the way home, noticed that the electric windows no longer seem to do the auto open/close thing??? They still work, they go up and down, all round, but they dont do the auto thing????? Any ideas, Is there a reset I can do???
After reconnecting a Battery the windows must be reset.Open then close each window with its own switch and hold the switch for 2 or 3 seconds after they close. This should normalize the auto close on the driver's window and re programme the anti-jam.
If this does not work. Have someone disconnect the Battery or fuse while the window is opening or closing (with the window motor operating) so the motor is forced to stop and then reconnect and then close and hold the switch.
Fitter
Thanks Fitter! I knew this place would come up with someone who knew what to do!!!
Update - confirm this works as advertised - Auto restored!!
Edited by PeaJay
