Losing Front End?
CUTEUKM786
When ever i drive over the paint markings on the road i seem to lose the front end of the car? sometimes the car oversteers and understeers? it seems to happen on wet roads at times aswell?
is that normal or could ther be a problem somewhere?
any help appreciated
What type of tyres do you have fitted? How are the tyre pressures?
Tyre pressure front is recommended at 32 and back at 30. it cant be wheel alignment because ive had that done recently.
Is it only in the wet? What's the tread depth of your tyres? Rubber still in good nick?
if it is only in wet, then it the type of tyre u r using.. some are absolute rubbish in wet...
do you just feel you are losing grip, do you feel that on your steering wheel...?? if u do feel on the steering wheel bushes mate, get them checked..have a look at the ARB drop links...
