Tns410 Disconnected My Phone And Refuses To Reconnect!
jamesj4
First post and its a problem!
I've had my Yaris for just over three months now and clocked up 700 miles. For these miles my phone has connected the TNS410 without any problem. However this evening I got "Phone Disconnected" on the Speakers and since then my phone has refused to re-connect! Tried the usual turning off the bluetooth, removing and re-installing the phone to no avail!
Any help greatly appreciated!!!
I've had my Yaris for just over three months now and clocked up 700 miles. For these miles my phone has connected the TNS410 without any problem. However this evening I got "Phone Disconnected" on the speakers and since then my phone has refused to re-connect! Tried the usual turning off the bluetooth, removing and re-installing the phone to no avail!
I had a similar problem with the Bury bluetooth in my car which kept disconnecting me. First thing to try is not just removing the phone from your TNS410 but remove the TNS410 pairing from your own phone. That didn't work for me so in the end I ended up backing my phone up then doing a factory reset and it's been fine since. For what its worth my wife has an iPhone 3g and it's been fine with her TNS410 but she moans like mad that it's not a patch on the factory fitted bluetooth that was in her previous TR that was operated from the steering wheel controls.
Wheyyy problem solved after 5 hours!!! I had already tried removing the pairing from my phone without success, in the end I reset my TNS410 to the factory settings which cured the problem. What didn't help me though was that there are no troubleshooters in any literature that came with the car. The only reference to bluetooth is in the main manual which is the factory fit one (which to me seems a better system because as you mention it has steering wheel mounted controls!)
Thanks for the help, and hopefully my next post will be positive!! :-)
