Cutting Out
woodywonka
Hello
A short note to ask if anyone has came across this problem
when I start the car from cold in the morning and reverse out my drive the car cuts out, and is then very difficult to start ie: I have to leave it for a minute or two before it will start.it does nt do it all the time but i,ve only had the car a month and its done it about 5-6 times
your thoughts would be appreciated
Woody
Sounds like its starved of fuel when its running rich. When it stops, pump that little plunger on top of the fuel filter until it goes stiff then try to start it again.
Hello
Woody
hi mate
1. Check with el contacts for SCVs;
2. Check with fuel filter - -may be it is time to chacnge it (1-2 mins are sufficient for diesel to be passed thru clogged fuel filter)
cheers/Igor
Check with el contacts for SCVs; ????? sorry you have lost me there
woody
He means the electrical contacts to the SCVs. You can find details in the pinned section.
cheers Anch !!! for correction in English wording
Igor
Thx all will give it a try :thumbsup: :thumbsup:
