guys
i have a 1993 1600cc 4afe engined carina
the engine warning light came on after driving 6 or 7 miles
when i arrived at my destination i switched off the engine and re started it the light didnt come on
it happened again later in the day
when the warning lights on she drives normaly
and the 3rd time i drove her it didnt
is this anything to worry about
what should i do
i fitted a new coil toyota fuel pump and leads last year
and she runs great with 215000 miles on her
regards andrew
I am not totally sure what the Engine warning light does on these cars to be honest. Have you done simple things such as checked the oil checked water level and things like that?
jack
guys
what should i do
regards andrew
hi sammy i had the same thing on my k reg 1.6 gli i would say at best it is the sensor on the exhust it not a majer problem i never noticed a lot of diferince in performance but i think it helps to tell the car how to tune its self sort of if that make any sence
Hi I had this on my Carina, its the lambda sensor or 02 sensor gone faulty, you can see it screwed into the exaust manifold it looks like a spark plug with 4 wires comming out, there pretty costly (3-400 euro) but i got a perfect match of eBay for around 100 + shipping, the car will still run normal enough but it uses more petrol and eventually it could ruin the cat if not changed, hope this is of use...
