hi all. need to change the cambelt on 97 picnic. is this an easy job, there is no manual for this vheicle avallable. many thanks.
no it's not easy i wouldent recomend doing it yourself unless your sure you know what your doing but the fact you just asked would tell me you dont
hello there have you tryed eBay for a manual.i have a toyota lucdia emina.and i got my cd off eBay..
haha - I remember buying a CD set for a Fiat Punto from eBay and it arrived...... but was written in Italian !
  • 5 months later...
did you ever change it, i did mine it is easy on this engine just time consuming if you fancy a go still i will write up a step by step you dont really need a manual as long as you are fairly good with a set of spanners
dear sibbs, no i never did get around to changing it,in fact since then my mileage has dropped considerably. due to early retirment. many thanks for your intrest and reply.
  • 7 months later...
hello i just changed my cambelt on my emina but i cant figure out the correct timing mark on the diesal pump could u please help it turns over but not diesals entering main pump chamber ..
  • 2 years later...
300 GBP at any good mechanic gets a timing belt and water pump ( not the 30
GBP eBay water pump ). I paid 450 GBP 5 years ao. I have a couple of addresses if interested.
