Hi, I've been searching for a Carina II suspension strut - front nearside - but no luck for quite a while now.
Does anybody know: are these struts (the whole thing that is bolted to the wheel bearing housing, minus the top mount and road spring), are they fitted to any other Toyota model. There seems plenty of Carina E parts about but the strut has a different look about it to the one fitted to my Carina II.
Does anyone know?
Robbie
Does anyone know?
Robbie
I can't help you directly about a front strut, but I've had no problems getting a pair of rear struts from my local motor factor - made by Monroe, so they probably do the fronts also. I hope so, as I expect I'll need a pair sometime.
Are you talking about the part that the wheel bolts on too? If yes, then you mean the hubs.
Next question is, are yours 4 stud or 5 stud.
Eighter way, if 4 stud, then it will be the same as other 4 stud Toyotas os similar age and front wheel drive and if 5 stud will be the same as Celicas of similar age.
