Celica St205 Gt4 Engine Coolant Fans And Cabin Heater Fans Not Working
mike-102
hi all could do with some help please, iv got a celica gt4 st205. the problem is the coolant fans are not kicking in, checked the fan sensor in the bottom right corner of the rad, joined the terminals together and the fans dont come on. checked the polarity one side was positive and the other was negative,im thinking of replacing the 3 coolant fan relays.also the cabin heater motor is not working, i have removed the air-con rad, pump, and air con pipes in the engine bay dont think this is the problem tho
any ideas ???????
Have you manually tested the cooling fans by applying a straight 12v to them?
the fan switch is on a fail safe system, simply unplugging it will cause the fan to come on. :thumbsup:
