Oil Leak From Injector
glappy mick
Hello everyone
My 2005 avensis 2.2d is leaking a significant amount of oil from the far left injector. The problems started yesterday when, at 70mph the engine went into limp mode and the malfunction, trc and vsc lamps came on. I restarted the engine and it ran smoothly for a while (the warning lights stayed on) then the engine went into limp mode again whilst accelerating at about 55mph, and again ran smoothly again when restarted. I was going to try and clean the egr valve but when i took the engine cover off i saw a lot of oil around the left side of the engine, and when the engine is running you can see oil coming out of the left injector.
I haven't found any other posts on this, I'm starting to think I've got a major problem!
Can anyone help?
Thanks, Mike
Hello everyone
Can anyone help?
Thanks, Mike
Can you take some pic's so we can see the problem?...
post-103031-0-33905700-1310578204_thumb.post-103031-0-48943000-1310578383_thumb.post-103031-0-33905700-1310578204_thumb.
Hello everyone
Can anyone help?
Thanks, Mike
Is the leaking fluid engine oil or diesel fuel??
I'm fairly sure its oil. It's black and the engine oil level has dropped a lot.
I looks like oil to me to! Does it smell of Diesel at all? Sometime it can leak from the fuel pipes. I serviced me mothers car the other day (Citroen C3 Petrol) and changed the spark plugs that have never been done (Onlu 22k on the clock) and when I looked down at the plugs I could see small pools of oil. Turns out that the spark pugs were only just touching the head and oil was escaping past the plugs. So I made sure I torqued the new plugs up correctly....
I looks like oil to me to! Does it smell of Diesel at all? Sometime it can leak from the fuel pipes flanges. I serviced me mothers car the other day (Citroen C3 Petrol) and changed the spark plugs that have never been done (Onlu 22k on the clock) and when I looked down at the plugs I could see small pools of oil. Turns out that the spark pugs were only just touching the head and oil was escaping past the plugs. So I made sure I torqued the new plugs up correctly....
It smells a bit of diesel, its probably a mix of the two
I think a trip to the dealer or a local Toyota specialist woul be a good move mate. :thumbsup:
me too. it doesn't look good.
Thanks for your help. :thumbsup::thumbsup:
No probs mate. Hope you get it sorted out. Have a check of those fuel pipes an see if the pipes are leaking pal. Let us know how you get on :thumbsup:
