Window Auto Function
daithiam
Hey everyone,
I have an Irish 2004 1.6 Avensis. Recently my Battery due to me leaving the lights and radio on. When i finally got a push and it started again I found out I lost the auto function on the drivers side window. I know this is only minor but its so handy and I would graciosly appreciate any help.
Many thanks
Dave
Hey everyone,
I have an Irish 2004 1.6 Avensis. Recently my battery due to me leaving the lights and radio on. When i finally got a push and it started again I found out I lost the auto function on the drivers side window. I know this is only minor but its so handy and I would graciosly appreciate any help.
Many thanks
Dave
There should be something in your handbook about that. The jam protection safety feature has to be calibrated after losing power. Here's what my owner's manual says:
If the power window does not operate
automatically or the jam protection
function does not operate correctly, you
should normalize the power window.
To normalize the power window:
1. Push down the power window switch
and lower the window fully.
2. Pull up the switch until the window
closes and hold the switch for a second.
Make sure that the window opens and
closes automatically. If the power windows
cannot be operated properly, have it
checked by your Toyota dealer.
Jam protection function (driver’s window only)
If an object becomes caught between the window and the window frame,
window travel is stopped and the window is opened slightly.
* When the Battery is disconnected
The power window must be initialized in order to ensure proper operation.
Step 1: Open the window fully.
Step 2: Fully close the window by pulling the switch up and holding it for 1
second.
