Hello friends
I want to start a important discussion and see how knowledge can be shared. Has anyone converted a 1kzte (Turbo EFI version) engine to run on Waste Vegitable Oil (WVO) or Virgin Vegetable Oil (VVO) dual tank or single tank system? Since the engine is non direct injection it is a super candidate to convert.
1. If someone has experience in this please share as much details since I am about to make a conversion. Particualry interested in WVO and home made biodiesel.
2. If there are problems in running please share experiences. I already know about the temperature issues but are there any other issues to worry on the fuel system.
3. If there is a tried and tested DIY conversion please recommend. I have already done lot of research and there is doubt which on to go with Toyota.
Regards
Arjuna
Hello friends
Regards
Arjuna
my only experience is that veg oil does seem to disolve the seals on the fuel pump, causing leaks
there is a rebuild kit with modern seals designed to cope better with bio diesels and the like
