2008 Estate Rear Light Lens
antred
Hi, does anybody know how to remove the rear light lens from a 2008 T180 estate? Mine has condensation and water in the fog lamp part so I want toi remove it and see if I can reseal it as I have been quoted £90+ just to supply a new one. Thanks for any advice
Thats crazy money! You can buy one off eBay for around £15... I'd have a look for a pdf file for you and post it. Unless someone gives you the info befor I get it posted :thumbsup:
Did you just ask a dealer for a price on it or have you had them look at it? Ive had a few rear lights changed under warrenty for the same issue as you now have. The most recent lights ive had in seem to be fine so they might have changed the design. But back to your question on taking the lights out from memory: reach in the rear panel and under clip the lights and pull them off the cluster and then there should be two nuts holding the light cluster on. It should then just pop out.
Thanks for the replies, I will have a go one weekend when its not raining, looked on eBay and they are for saloons (different shape. The quote of £95 was for supply only from a main dealer, didn't try the warranty route as my car is over 3 years old.
Thanks for the replies, I will have a go one weekend when its not raining, looked on ebay and they are for saloons (different shape. The quote of £95 was for supply only from a main dealer, didn't try the warranty route as my car is over 3 years old.
One on eBay atm (Estate car) for £80 (Item number: 380327098998) But he wont get that I bet. So the dealer one sounds like a good deal for new one. But If you dont get sorted out on the weekend it might be worth seeing if you can get it done under warranty. Even if they do not replace if FOC then there are usually "Gesture of good will" that the dealer can use to Toyota Uk on your behalf if the car has been looked after and serviced by a main dealer.:thumbsup:
