What Are These On Instrumental Panel
bickyz
hi i just bought this Yaris 1.4 D SR (2009)
On the instrumental panel if i press the switch/button on right it toggles from these
1. odo - total number of miles the vehicle has done so far
2. Trip A
3. Trip B
4. xx mpg
5. xx mpg on this one AVG appears near the fuel level
6. xx miles
7. xx mph
I know what 1, 2 , 3 are. Can someone please explain what rests are for, the manual doesnt seems to be clear.
4 seems to give me fuel consumption based on the speed.
Also in the manual it says fuel tank capacity is 42 litre or 11.1 gallon. Is this including reserve?
what is the capacity of the reserve tank
how many average miles it gives once last bar displays for fuel level.
thank you, help will be much appreciated.
2. Trip A
3. Trip B
4. xx mpg
6. xx miles
7. xx mph
4. The fuel consumption at that instant.
5. The average fuel con. since filling the tank.
6. The approx distance you can travel with the remaining fuel.
7. I've forgotten :blink:
1 - 6 as Bos says.
7. Average mph since filling the tank. :thumbsup:
1 - 6 as Bos says.
Thanks for remembering no.7
It must be my age :rolleyes:
thanks to Bos & stantheman1.
what about these:
thank you
In the petrol version (probably the same for the diesel) there's approx. 7 litres of fuel left when the final segment starts to flash and average miles left (even when 'miles left' shows zero) is dependant on driving conditions if that makes sense.
i hav 2 bars in the fuel n number 6 "approx distance i can travel wit remaining fuel" says 0 miles.
is there smthing wrong.
No problem bickyz, it'll just be what the computer thinks after the previous fuel load and current driving conditions. Often if you're covering more miles than you did before when you fuelled up. Did you put in more fuel in this time than you did previously? The computer learns all the time though it isn't 100% accurate. Clearly in your car's case! It will improve though. As long as the fuel gauge isn't blinking, you've got enough left to not have to worry, despite "approx. distance I can travel with remaining fuel" being 0 or 100
thanks adman.
I did topped-up £5 worth fuel.
