Who knows the correct Offset the Corolla T SPORT must use in a 16x7 wheel>>>???
I think ET is either 35 or 37 mm depending on the wheel manufacturer...
Hi there,
The T-sport uses 6x16 wheels with ET45 offset as standard. You should be able to use any offset between ET38 and ET45 depending on the manufacturer. They will give you the correct offset. Cheers
I'm not an expert on this, and I've tried to check wheel manufacturer's web sites (OZ, BBS, Mille Miglia, ATP etc.) for E12 Corolla wheel compatibility. It seems that lots of wheel manufacturers offer E12 Corolla wheels (7 x 16) with ET35-38. My wheels are 7 x 16 with ET37. ATP site recommends ET should be 40mm -> for 2002 Corolla. Smaller wheel offset may cause some problems, but is the difference significant?
