96 Rav4 Immobilizer
John Bosson
Hi all
new to this forum
just bought a 96 RAV4 non runner
Have trawled this forum and the internet before posting this - so here goes
Starts and runs for about 2 seconds, then dies
assertained that this must be the immobiliser not registering the key
Seen posts relating to removing the immobilizer but this seems to be relating to just removing the alarm,
the immobilizer on my model cannot be removed or bypassed as the main ecu needs a signal from it.
From my research I have found that the code is stored on a plug-in eeprom in the immobilizer
This eeprom can be programmed with virgin or reset code that registers the key (any key) when it is inserted for the first time.
the part no for my immobilizer is 89780-42010 and the chip is a 93LC66 which can be programmed using a standard microchip eeprom programmer
hope someone can shed a bit more light on this - as only theory at the moment and our lass wants her new car running soon.
cheers
John
Welcome to the forum.
The original alarm and immobiliser was fitted to the RAV4 (1994 models) when they arrived in the UK. Unfortunately the company supplying them went bust, as did their alarms some years later, hence the posts about removing the annoying thing.
Slightly later, and it seems to be random cars in 1995, another alarm was fitted with the transponder thingy in the key. I don't know much about this one other than its a fairly basic thing.
I'd personally get the thing removed by an auto-electrician - not many crims are looking for a 15 year old car to nick.
thanks for the reply
the whole idea though, is diy so others can also do it themselves
The eeprom is only 18p, just need the virgin code
will update when i find the diy solution
Another solution would be to swap the ecu for a pre- eeprom jobbie. Its the same engine etc after all.
good idea
does anyone have the part no
cheers
Up and running
got diagnostics procedure from a mate who works for Toyota
reprogrammed eeprom
will post full details in a new thread soon
