guys hope one of you may help me out. i have a toyota corrolla sedan which shakes at 105km/hr and stops shaking at 120km/hr. i have tried balancing the wheels but it did not help out. i had one guy check the suspension and he says its okay. can anyone help me out
Moved to Corolla Club forum where hopefully you will get an answer!
Check that there is nothing like dirt rust stuck between wheels and hub.
Check your tyres are not deformed too.
Did you get all four wheels balanced or just the front.the rears need doing too or you'll get the same effects.
buckled wheel maybe? but i think that would shake all the time? make sure you have all 4 wheels balanced properly not the cheap job where they claim your wheel is balanced when the machine says 5 or even 10g still to add!
check bushes, shocker top mounts? check your springs for cracks? problems like this i've had my fair share of and there are so many variables suspension, steering, wheels, bearings etc its hard to put your finger on the problem.
  • 9 years later...
Check also transmission shaft sometimes they just give up...
Topic is nine years old....
kkkkk Sorry !!!
