Bg244
The Cav
As my topic description asked
I have bought a can of BG244 diesel injector cleaner
(its on offer from power enhancers)
I'm lead to believe it really is the dogs goolies so i am hoping its going to help with the bit of excessive black smoke from my 2.2
which BTW is doing the spot on mileage of 37.2mpg URBAN... which is near as damn what the Toyota people say the car should do according to the Toyota literature
the egr is clean so is the maf
ive tried everything else inc forte ,Wynn's Red Ex all to no avail
so the question is....is bg244...worth the money
In my opinion it worth the wonga. But there has just been a report from a member on here that in his view its not done its job on cleaning the EGR valve. But for me I think it does work to a point. As no fluid is going to completely clean a valve that is dirty.
Not cheap but good stuff.
I noticed a difference & the car will be getting it again after 10K.
I would be surprised if it can survive the combustion process and then go on to clean components in the exhaust stream so I can't see the EGR valve, etc gaining any benefit.
I have never used any fuel or oil addditive or any car over the past forty-odd years.
If an engine ain't performing correctly I fix it.:)
The engine oil and fuel your using now is full of 'em ! :D
That may well be the case. All the reason not to buy expensive additives.
Occasionally problems and certain situations need a little extra help :)
