Changing Wing Mirror Glass?
Avanzato
Guys,
After a nice chappy in a transit pickup smashed the glass in my wing mirror I need to change it. Is it an easy job?
New glass should be here Tuesday.
Thanks.
:yes: Yeah, dead easy! IIRC there are two locating tabs on the mirror backing that slide into two corresponding slots/holes in the mirror housing then at the opposite end of the mirror there are two lugs that clip into place when the mirror is pushed right back.
When you get the new mirror you will see how it fits and how to remove the brocken one.
Hope that makes sense.
Glad you're getting a proper replacement as those that you stick on top of the broken glass are really pants!
EDIT:
Just noticed your's is a T Sport so could be slightly different, but you will see how it fits when you get the new one.
