Gear Stick Vibration
Brandy
When in 5th gear my gear stick vibrates when I reach 60mph when I go faster , It does go away if iput my hand on the gear stick very very nippy when you need to go at a steady 60 ,any ideas.all other gears are ok just when you build up to 60 it rattles. 2.0 d4d
On the original box, yer paw on the stick led to 5th gear popping oot.
Have ye been tae yer dentist recently? Or maybe try changing yer fixadent tae anither brand ??? :lol:
(If none of these then good luck with findin the cause)
I very guid San
After having a vibration on my 5th gear for a number of years and only whilst in 5th gear at speeds between 60 and 75mph I found out the problem, the 5th gear synchro went. The 5th gear was replaced and now does not rattle or vibrate at all however it cost £550.00 at a local gearbox specialist.
I would get this checked out and replaced/repaired before it goes totally.
cheers
