Avensis Immobiliser Reset Help
dannylatimer
i brought a lemon so it seems, i viewed this car 1 day, it started ok, though the idle was running high for a min then ticked over nice. the rad fans didnt work so we diagnosed that the temp sensor was duff because when we unplugged this the fans worked. i needed these to work as to drive home the next day when i collect it.
next day i payed the man, flipped the bonnet and unplugged the fan sensor. tried to start car but had v low Battery power as fans were running immediatly.
reconnected sensor and tried to start car. it seems to want to start but cuts out immediatly. it will fire for about 1-2 seconds.
i have googled many theories and found some say its the immobiliser cutting the fuel pump, some say its the ignition barrel. is there a way i can fix this without an expensive fault finding computer?
extra info : we disconnected Battery over night for a recharge. no help,
tried resyncing the keys, no help. (though unsure if method was correct)
diconnected Battery, opened driver door, put key to ON in ignition, reconnected battery, no help.
hi mate had the same problem with mine and it turned out it was the ignition switch cost about 60 pounds on toyota and about 40 on eBay
hi mate had the same problem with mine and it turned out it was the ignition switch cost about 60 pounds on toyota and about 40 on ebay
try remove the ignition switch and then with the key in the lock use a screw driver to tur the ignition if it starts u know u found ur problem
