What Is Toyota Oil?
Roker
Not a fault just an observation. I just had a service and had Castrol Edge in from the previous service, when the engine was cold I had a ticking noise (sounded a bit like piston slap).
I just had a Toyota Service and since the service this noise seems to have disappeared, I asked The Toyota dealer what oil they put in, the answer, Toyota Oil, 5 -30 synthetic, not the answer I was looking for. Toyota do not make oil so which company provides it?
TGMO (Toyota Genuine Motor Oil) as you say is not made by Toyota, but it is made to a spec, supplied by Toyota, from I suspect whoever gives the best deal on the open market. For a long period it was made by ESSO, but these days, the COSHH sheets only give Toyota Europe as the point of contact and not the manufacturer
So in short, I think it is made to a specification by any one of the large suppliers
Kingo :thumbsup:
I emailed Toyota Ireland after reading this, and they telephoned me back yesterday. Says that the oil is manufactured to Toyota's specifications by Chevron.
I must have a look at a bottle of havoline and see does it look like toyota's...
just buy some 5/30 semi or fully synthetic oil
the req'd spec is in the hand book....but its all a load of nonsense in the long run
its just another rip off....TESCO HAD Castrol MAGNATEC 5/30 FULLY SYNTHETIC ON OFFER A FEW WEEKS BACK £25.50 FOR 3X2LTS
this oil is totally perfect for your requirements
Or maybe this eBay Item number: 110701131801
£107 for 20ltrs delivered... I think this is the fully synth version of the oil?
Lucas Semi Synthetic Motor oil is a blend of high quality base stocks and an exclusive high performance additive package that ensures minimum drag, extended engine life, longer oil life and easy cold weather starting.
The exclusive additive package in Lucas Semi Synthetic Motor Oil is excellent for use in turbo charged engines.
Designed for use in both petrol and diesel engines.
For use in 4-cylinder, 6-cylinder and 8-cylinder Petrol and Automotive Diesel Engines
Meets or Exceeds American and European OEM specifications API SM/SL/SJ/CF, ACEA A5/B5-04, A3/B4-04, C2-08, C3-07, C2-04, MB229.31, MB229.51, VW 50200, 50500, 50501, BMW Longlife-04, Porsche, Ford WSS M2 C 917 A. Suitable for use where VW 50700 is recommended
