2.0 D-4D Engine Oil
UnReaLT
My owners manual states that for the 1ND-TV engine fitted with a DPF catalytic convertor 0W-30 is used at manufacture and is the best choice. Without DPF catalytic convertor - 0W-30 or 5W-30 is OK. However oil below ACEA C2 may damage the cat - the oil you've identified is ACEA C1 which presumably is below the required spec.
maybe this one is OK ?
http://www.shell.co.uk/home/content/gbr/products_services/on_the_road/oils_lubricants/shell_helix_tpkg/product_range_new/helix_ultra_extra/
If you go on the Shell website and enter you reg number they advise you which of their oils is suitable for your engine.
I've gone with the Mobil 1 ESP 5W-30 Fully Synthetic Engine Oil, which meets the specifications for my 1AD-FTV engine.
Better to be safe then sorry.
Thanks for the replies, I had a flick through the manual and this oil meets the ACEA C2 specs.
http://www.opieoils.co.uk/p-68973-shell-helix-ultra-extra-5w-30-premium-fully-synthetic-engine-oil.aspx
