Turbo
Supraman81
Just cant seem to find the problem i checked all the hoses and the fan seems to be fine but its not building presure can any one help
If your not building pressure then the boost must be going somewhere other than the intake.
Is the wastegate shutting?
Have you got an aftermarket dump valve? - if so try removing it temporarily
Have you checked the turbo gaskets? Does it sound like there is any blowing?
Have you checked the ECU for engine codes?
Is there a hole in the intercooler?
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
