Replacing Rear /tail Light On Body (Driver's Side)
Titu
Can anyone give me some information about replacing the Rear?Tail light on a Toyota Yaris 1.3 T3 5 door hatchback (2006)? Is it quite straighforward to diy?
All replies are greatly appreciated.
Many thanks.
Many thanks.
Yes very easy.
Either side in the boot are 2 plastic grilles. Depending which side you need to replace lever out from the top with a flat bladed screwdriver. You will be able to see all the bulbs mounted in a plastic holder. At the top is a plastic clip poking out. Lift this clip and the plastic holder with come out with all the wires still attached. It is easy to replace any bulb. To put the holder back is the reverse procedure. :thumbsup:
think he means the whole light...same as above then look for the three 10mm nuts remove these then pull off
