Bg244
The Cav
After trying all the rest inc FORTE REDX AND MILLERS ETC ETC ETC
to limited success i tryed the BG244
ok its pricey
BUT IT IS FANTASTIC NO MORE SMOKE ,TOTALLY RESTORED PERFORMANCE
JUST AS THE TOPIC DISCRIPTION
flaming FANTASTIC IS THE ONLY WAY TO DISCRIBE IT ETC...the car is so responsive now
MY 2.2 D4D IS TOTALY REFORMED......THE DOGS GOOLIES
I just hope it stays like that and doesn't go back to the way it was after its had a few more gallons of fuel through it
Totally agree
Its the real deal and does what it says on the tin
no more wasted money for me on the other fuel cleaners ...ONLY BG244 FOR ME FROM NOW ON
I used it. Think it cleaned it so well that it moved a big chunk of crap into somewhere else! Righted itself after a few fills. It does get very good recommendations. I was able to pick it up at a car dealership's parts store.
Just put some of this stuff in for the first time - smells very similar to Millers Sport(which I use regularly). Must have some similar ingredients but probably not the octane (cetane ?) improver.
Please let us know what you think Tubaman
I have previously used millars but only the standard ...didnt know there was a SPORT VERSION
Anyway try the BG244 and PLEASE REPORT BACK and let us know your findings
I Personally think its SUPERB
Before using the BG244... I used to get some black smoke if i went into a turn and tried to accelerate back up to speed ...not anymore
Has anyone tried the petrol version of BG244 (forget what its called) if so, were they pleased with the results.
got no trouble with my vvti, but just interested.
BG44
The Power Sport4 was the newer version of Millers diesel additive which in turn has been superceeded by the present Millers Diesel Power Eco Max Treatment.
BG44
Hi dervdave.
thats the one, thanks, but has anyone used it,if so what were the results.
YES Thats the millars i tried previously
NOT AS GOOD AS BG244 imo
It Didnt give the same superb results as the BG244
infact With the millars It was hard to notice any difference between the ... RedX... Forte...STP and all the other roughly priced the same additives
I have tried them all since buying My Avensis in January 2010 (Its always been a bit smokey ...not now though.. I think it must have had a sticky injector ...people have said to me ... the smoke was definatly unburnt fuel)
Back to all the different additives ive tried on average they cost Approx £6 (except the forte which is approx £10)where the BG244 is £24 delivered...id have been pounds in when i started buying these injector cleaners if id know about the BG244 before i bought all the other not as good additives...honestly they did a little bit of helping to improve with the eradication of the black smoke but not totally
Where As The BG244 at present seems to have completely solved the problem
IMHO, additives for petrol cars are like perfume for women.
It does not make them look prettier... :unsure:
10 pints of STELLA Helps in that situation...lol
No wonder my liver is in the state its in ! :rolleyes:
I Have ordered this.
I wonder what effect it will have on an avensis which has nearly done 350k
350k ????? *****, its good but don`t expect miracles ! :lol:
It drives like new :)
Still pulls strong in everygear.
I`m pleased to hear it, the motor must`ve been looked after, what new fuel system components has it had replaced ?
I`m genuinely interested in how you find the car after using the BG244 so please give an update. :thumbsup:
The only thing replaced on this car is
Dual Mass and cluth
Afew wheel bearings
discs, pads and oils.
Injectors and pump are all standard.
Its smoking black under heavy load (wot)
its ready for its annual sensor clean and fuel filter replacment etc
Dual Mass and cluth
Afew wheel bearings
Thats !Removed! good going ! :)
Dual Mass and cluth
Afew wheel bearings
Thought the answer was going to be like Triggers Broom.
So its done very well indeed.having only one DMF is good going,the car must have well treated
Dual Mass and cluth
Afew wheel bearings
Car is driven by me as a Taxi.
Serviced and checked every month.
Well Guys
Alittle update.
Serviced the car yesterday
New Oil
New Oil Filter
New Fuel Filter
Clean MAF
Checked some other stuff.
Poured in the 25£ worth can of BG.
Filled up with Shell Diesel.
Have done around 30 Miles.
Car feels the same, same ammount of black smoke is emmited
no changes so far
Cheers for the update so far, its early days yet.
As a point of interest have you ever used any sort of additive/cleaner in this engine ?
Yes give it time ....I think it took about 100 miles before it worked on my Motor
My 109000 (nearly) 2.2 is still smokeless even the missus has noticed the difference...and it seems more rapid.... I am really looking forward to a 250 mile trip down south in 4 weeks time with the wife... just to compare it to when I last went on a good run which was in June... before the BG244 was put in the tank
I had my son follow me last week and he said that there was no black smoke at all from my motors Exhaust
BTW my Avensis always left a plume of smoke when I went right at a turning onto the housing Estate where I live
now it doesn't
Please report back after a 100+miles or so
