Camry: Blue Smoke From Old Valve Stem Seals - Any Additives/oil Advice
tricky.bob
I just got my first Camry. A 1999 3.0 V6 in purple [it's sooo not purple, and sooo lilac!] - Yay!
So I have blueish smoke coming from the exhaust at start up that lasts for about 10-15 seconds.
I tested for condensation [it's not wet to touch], and have check the filler cap and dip-stick - both clean and the oil is very clear. I figure this means the head gasket is ok.
That [i think] means the issue is probably coming from the valve stem seals hardening and allowing a small drop or 3 through into the cylinders.
My question is, firstly, am I missing something obvious? ; and secondly what do you guys recommend using to prolong the life of the seals - Oils or additives for example?
The Camry has 97000 miles on the clock and cost £1200. I don't have the money to get the valves replaced as I assume that would be very expensive - any ideas on how much that would cost [in the UK]?
