Noise When Steerining At Very Low Speeds (Only From Left To Right)
786innovation
My avensis 2002 vvti 1.8 GS makes noise when cutting steering from far left to right during parking or slow movement. It doesn't make noise when I move steering from right to left. What will be the problem? does the steering immidiate shaft need greasing(lubrication)?? if yes the how to do it??? FYI, Steering fluid is ok, up to the required level. Thanks in advance
